AliKelman
Dec 01, 2022Guide
Suitable upgrade for an EN108
I've got a patch panel in my home (!) with CAT5 wiring running into various rooms from the patch panel. The patch panel is served by a Netgear EN108 switch. I want to upgrade this to add extra wired...
AliKelman
Dec 03, 2022Guide
I am bidding on a NETGEAR GS728TP-100NAS ProSafe 24 Port Gigabit Poe Smart Switch on eBay at the moment. I should know on Monday morning if I have won it.
michaelkenward
Dec 03, 2022Guru - Experienced User
Good luck. PoE is new to me.
Well, I did use it man y years ago for something or other – still have the bits lying around – but haven't had the need since,
Did you get the manual for it?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation.
