AliKelman
Dec 01, 2022Guide
Suitable upgrade for an EN108
I've got a patch panel in my home (!) with CAT5 wiring running into various rooms from the patch panel. The patch panel is served by a Netgear EN108 switch. I want to upgrade this to add extra wired...
schumaku
Dec 03, 2022Guru - Experienced User
AliKelman wrote:
NETGEAR GS728TP-100NAS ProSafe 24 Port Gigabit Poe Smart Switch
Manuals, firmware and more https://www.netgear.com/support/product/GS728TP
AliKelman
Dec 06, 2022Guide
I won the auction on eBay yesterday for a second hand NETGEAR GS728TP-100NAS ProSafe 24 Port Gigabit Poe Smart Switch. It is deeper than the cabinet but that is not going to be a problem since I can rest it at an angle (see photograph). Tomorrow (Wednesday) I plan to connect it up. I powered it up and everything lit up seemly OK - there is a quiet fan which is not going to be an issue in the cabinet.
