habys
Apr 23, 2020Aspirant
Switch keeps dropping config
Switch is mounted in a rack and powered by a dedicated 30a 240v circuit via a APC 5000 UPS. Switch does not appear to be running hot, nor are the fan ports blocked by anything. The switch will period...
JohnC_V
Apr 27, 2020NETGEAR Employee Retired
Welcome to our community! :)
We might need to check the tech support file in order for us to know if this is already a hardware issue. May you be able to send the file via pm?
John
NETGEAR Community Team
- habysApr 27, 2020Aspirant
I don't mind to send it, but I am curious: Are you saying there's a non-hardware situation in which this model switch repeatedly drops it's config?
- JohnC_VApr 27, 2020NETGEAR Employee Retired
That is why we do need the tech support file in order for us to check what seems to be going on with the switch and identify which causes the problem.
John
- habysApr 28, 2020Aspirant
Sent two logs, I was going to send another log but it's down for more than 10 minutes, I'll need to power cycle it to get it to do anything again. Most of the times it freaks out it it comes back by itself.
