habys
Apr 23, 2020Aspirant
Switch keeps dropping config
Switch is mounted in a rack and powered by a dedicated 30a 240v circuit via a APC 5000 UPS. Switch does not appear to be running hot, nor are the fan ports blocked by anything. The switch will period...
habys
Apr 27, 2020Aspirant
I don't mind to send it, but I am curious: Are you saying there's a non-hardware situation in which this model switch repeatedly drops it's config?
JohnC_V
Apr 27, 2020NETGEAR Employee Retired
That is why we do need the tech support file in order for us to check what seems to be going on with the switch and identify which causes the problem.
John
NETGEAR Community Team
- habysApr 28, 2020Aspirant
Sent two logs, I was going to send another log but it's down for more than 10 minutes, I'll need to power cycle it to get it to do anything again. Most of the times it freaks out it it comes back by itself.
So it never came back. It's just down. My studio isn't functioning when this switch is down, and I can't seem to get anywhere with support. This is terrible.
