robfantini
Aug 29, 2017Aspirant
switch set to fixed IP looking for a dhcp address.
Hello Product Name M4100-50-POE ProSafe 48-port FastEthernet L2+ Intelligent Edge PoE Managed Switch, 10.0.2.26, B1.0.1.1 This switch is set to have a fixed . yet it keeps asking for a...
- Sep 23, 2017
since the switch is working great, i choose to just filter log lines from mac address of switch to /dev/null at rsyslog.conf .
JohnC_V
Aug 31, 2017NETGEAR Employee Retired
Hi robfantini,
As per checking in here that the switch is still requesting for an IP even if it set already to static. Have you tried resetting this to factory default then reconfigure and check if it will be producing the same issue? You may also try reserving an IP for the switch in the DHCP server and let's see how it goes.
robfantini
Sep 01, 2017Aspirant
The DHCP server was already set up with a fixed lease for the switch.
hopefully there is another way to attempt a fax besides a factory reset.
- JohnC_VSep 02, 2017NETGEAR Employee Retired
This is just part of our work around to double check if the switch will work from its default settings.
- robfantiniSep 04, 2017Aspirant
I'll do the reset in a couple of weeks..
- robfantiniSep 23, 2017Aspirant
