robfantini
Aug 29, 2017Aspirant
switch set to fixed IP looking for a dhcp address.
Hello Product Name M4100-50-POE ProSafe 48-port FastEthernet L2+ Intelligent Edge PoE Managed Switch, 10.0.2.26, B1.0.1.1 This switch is set to have a fixed . yet it keeps asking for a...
- Sep 23, 2017
since the switch is working great, i choose to just filter log lines from mac address of switch to /dev/null at rsyslog.conf .
robfantini
Sep 01, 2017Aspirant
The DHCP server was already set up with a fixed lease for the switch.
hopefully there is another way to attempt a fax besides a factory reset.
JohnC_V
Sep 02, 2017NETGEAR Employee Retired
This is just part of our work around to double check if the switch will work from its default settings.
- robfantiniSep 04, 2017Aspirant
I'll do the reset in a couple of weeks..
- robfantiniSep 23, 2017Aspirant
