suppbod
Aug 12, 2024Follower
Transceiver is not accessible
Hello, i've seen the follwing Errors in my Log, but I am not able to identify the tranceivers: <11> Aug 12 01:05:37 Core-3 DRIVER[unitMgrTask]: hpcsfp.c(489) 6475008 %% s/p(0/15): Task: bcm_r...
RennaD
Aug 13, 2024NETGEAR Moderator
Hello suppbod,
Welcome to the NETGEAR Community! 🙂
You are right, the port numbering for the M4300-96X should be in the format unit number/slot number/port number. I sent you a pm, kindly reply back to it with the Tech Support file so we can check. To download Tech Support file just go to Maintenance > Export > HTTP File Export, select Tech Support for the File Type and hit Apply.
Have a lovely day,
RennaD
Netgear Team
