malacore
Jul 01, 2024Aspirant
Unable To Load Firmware On GSM7328Sv2
I was recently gifted a GSM7328Sv2 that was not factory reset before being given to me. I did not have the credentials for the switch so I pressed the factory reset button, but now there is no firmware installed.
Before I factory reset the switch, I was able to see link lights on the switch if I plugged my PC into it via ethernet. Now there are no link lights while the switch is on.
I have attempted to load new operational code using XMODEM and USB, and download a file through XMODEM but it ends up freezing after a certain point. This behavior happens in both ExtraPutty and Tera Term. I have also attempted the 30-30-30 reset but the issue persists.
Below is what appears in the terminal when the switch is booting up:
NetGear Boot code......
Version 01.00.33 02-03-2011
CPU Card ID: 0x508541
Flash: mtd: Buffer write verification failed (interleaved word mode)
Flash: @ 0xFE00 0000 + 0x00000060 wordsWritten: 192 count: 64
Flash: @ 0xFE00 0000 + 0x00000000 wordsWritten: 0 count: 64
Flash: @ 0xFE00 0000 + 0x00000000 wordsWritten: 0 count: 4
Flash: @ 0xFE00 0000 + 0x00000000 wordsWritten: 0x0ffffd2 count: 04 (
tRooFlash: mtd: Buffer wtTaskrite verificati): on failed (interltrouble / trouble
ea0xved word mode)
fffFlash: @ 0xFE00 0000fd20 + 0x (0000000tR0ootTask wordsWrit): ten: markAllocMa0p ERROR line co1485unt: in ftllite4.c
0xFlash: mtd: Bffffd20uffer write v (erification failedtRootTask (interleav): ed word mode)
marFlash: @ 0xFE00 0000kAllocMap ERROR line + 0x 000000014850 i wordsWritten: n 0ftllite.c
count0x: ffffd204 (
tRootFlash: mtd: Buffer wTaskrite verificatio): n failed (interlemarkAllocMap ERROR laved word mode)
ine Flash: @ 0xFE00 00001485 + 0x in ftllite0000000.c
00x wordffffd20sWritten: (0tRootTask count:): markAllocMap ERR4OR line
1485Flash: in ftllite.c
mtd: 0xBuffer write verifffffd20ication faile (d (interleaved wortRootTaskd mode)
😞 Flash: @ 0xFE00 0000markAllocMap ERROR l + 0xine 000000014850 in ftllite.c
Flash: mtd: Buffer write verifica0xtion failed (interffffd20leaved word m (ode)
tRootTaskFlas): h: @ 0xFE00 0000 markAllocMap ERROR l+ 0xine 000000014850 in ftllite.c
Flash: mtd: Buffer write verificat0xion failed (interlffffd20eaved word mo (de)
tRootTaskFlash): : @ 0xFE00 0000 +markAllocMap ERROR l 0xine 000000014850 wordsWritten: in0 ftllite.c
count: 4
Flash: mtd: Buffer write verificati0xon failed (interleffffd20aved word mod (e)
tRootTaskFlash:): @ 0xFE00 0000 + markAllocMap ERROR l0xine 000000014850 i wordsWritten: n 0ftllite.c
count: 4
Flash: mtd: Buffer write verification fa0xiled (interleaved ffffd20word mode)
(Flash: @ 0xFE00 0000tRootTask + 0x): 000markAllocMap ERROR l0000ine 01485 word in ftllite.c
Flash: mtd: Buffer wr0xite verification fffffd20ailed (interl (eaved word mode)
tFlash: @ 0xFE00 0000RootTask + 0x): 0000markAllocMap ERROR l000ine 01485 words in ftllite.c
Written: 0 count: 4
Flash: mtd: Buffer wri0xte verification faffffd20iled (interle (aved word mode)
tRFlash: @ 0xFE00 0000ootTask + 0x): 00000markAllocMap ERROR l00ine 01485 wordsW in ftllite.c
ritten: 0 count: 4
Flash: mtd: Buffer writ0xe verification faiffffd20led (interlea (ved word mode)
tRoFlash: @ 0xFE00 0000otTask + 0x): 000000markAllocMap ERROR l0ine 01485 wordsWr in ftllite.c
itten: 0 count: 4
Flash: mtd: Buffer write0x verification failffffd20ed (interleav (ed word mode)
tRooFlash: @ 0xFE00 0000tTask + 0x): 0000000markAllocMap ERROR l0ine wordsWritten1485: in ftllite.c0
count: 4
Flash: mtd: Buffer write 0xverification faileffffd20d (interleave (d word mode)
tRootFlash: @ 0xFE00 0000Task + 0x): 0000000m0arkAllocMap ERROR l wordsWritten: in0e count: 14854
in ftllite.c
Flash:0x mtd: Buffer writeffffd20 verification ( failed (interleavtRootTasked word mod): e)
markAllocMap EFlash: @ 0xFE00 0000RROR line + 0x14850 in ftllite.c
Flash: mtd: Buffer write ve0xrification failed ffffd20(interleaved (word mode)
tRootTaFlash: @ 0xFE00 0000sk + 0x): 0000000mar0kAllocMap ERROR lin wordsWritten: e 01485 count: in 4ftllite.c
Flash: mtd: Buffer write ver0xification failed (ffffd20interleaved w (ord mode)
tRootTasFlash: @ 0xFE00 0000k + 0x): 0000000mark0AllocMap ERROR line wordsWritten: 01485 count: in f4tllite.c
Flash: mtd: Buffer write veri0xfication failed (iffffd20nterleaved wo (rd mode)
tRootTaskFlash: @ 0xFE00 0000): + 0xmarkAllocMap0000000 ERROR line 01485 wordsWritten: in ftllite.c
0 count: 4
Flash: mtd: Buffer write verif0xication failed (inffffd20terleaved wor (d mode)
tRootTaskF): lash: @ 0xFE00 00markAllocMap ERROR l00 + 0xine 000000014085 wordsWritten: in ftllite.c
0 count: 4
Flash: mtd: Buffer write verifi0xcation failed (intffffd20erleaved word ( mode)
tRootTaskFl): ash: @ 0xFE00 000markAllocMap ERROR l0 + 0xine 000000014805 wordsWritten: in ftllite.c
0 count: 4
Flash: mtd: Buffer write verific0xation failed (inteffffd20rleaved word (mode)
tRootTaskFla): sh: @ 0xFE00 0000markAllocMap ERROR l + 0xine 000000014850 in ftllite.c
count: 4
count: 4
Flash: mtd: Buffer write verificatio0xn failed (interleaffffd20ved word mode ()
tRootTaskFlash: 😞 @ 0xFE00 0000 + 0markAllocMap ERROR lxine 000000014850 in wordsWritten: f0tllite.c
count: 4
Flash: mtd: Buffer write verification0x failed (interleavffffd20ed word mode) (
tRootTaskFlash: @): 0xFE00 0000 + 0xmarkAllocMap ERROR l0000000ine 01485 w in ftllite.c
Flash: mtd: Buffer write verification 0xfailed (interleaveffffd20d word mode)
(Flash: @ 0xFE00 00tRootTask00 + 0x): 0markAllocMap ERROR l000000ine 01485 wo in ftllite.c
Flash: mtd: Buffer write verification f0xailed (interleavedffffd20 word mode)
Flash: @ 0xFE00 0000( + 0xtRootTask00000): 00markAllocMap ER0ROR line wordsWr1485itten: in ftll0ite.c
count: 4
Flash: mtd: Buffer w0xrite verification ffffd20failed (inter (leaved word mode)
tRootTaskFlash: @ 0x): FE00 0000 + 0xmar0000000kAllocMap ERR0OR line wordsWri1485tten: in ftlli0te.c
count: 4
Written: 0 count: 4
count: 4
Flash: mtd: Buffer write verification faile0xd (interleaved worffffd20d mode)
(FlatRootTasksh: @ 0xFE0): 0 0000 + 0xmarkAl0000000locMap ERROR 0line wordsWritte1485n: in ftllite.0c
count: 4
0 count: 4
0 count: 4
0 count: 4
count: 4
count: 4
count: 4
count: 4
count: 4
Written: 0 count: 4
ritten: 0 count: 4
itten: 0 count: 4
count: 4
0 count: 4
0 count: 4
0xffffd20 (tRootTask): markAllocMap ERROR line 1485 in ftllite.c
0x3b41d00 (tXbdServiceActiveImage coul): d not be found
Unable to open e im1485age1 in ftllite.
c
active image fai0xled crc check. act3b41d00ivating backu (p image
tXbdServiNo Backup Image avaicelable.
😞 Failed tcheckStatus() ERROR o activate Backup Imline age.
1566
Operational code CRC is invalid.
Boot Menu
Options available
1 - Start operational code
2 - Change baud rate
3 - Retrieve event log using XMODEM
4 - Load new operational code using XMODEM
5 - Load new operational code using USB
6 - Display operational code vital product data
7 - File system directory listing
8 - Update boot code
9 - Delete backup image
10 - Reset the system
11 - Restore configuration to factory defaults (delete config files)
12 - Activate Backup Image
13 - Password Recovery Procedure
14 - Upload a file through XMODEM
15 - Download a file through XMODEM
Start about here .... with tftp
- malacoreAspirant
How do I utilize TFTP? I can only access the Boot Menu via serial cable. These are the options. Thanks!
Boot Menu
Options available
15 - Download a file through XMODEM- schumakuGuru - Experienced User
So no other options ... XMODEM or USB copy (FAT16 or FAT32 file system required) the -correct- image over a serial line, but not before setting the highest baud rate available on the switch. FMI: here (read the full thread please on a similar switch model).
