jtpubcon
Aug 16, 2013Novice
Upgrade GSM7352Sv2 To Firmware 10.0.0.31 Fails
I am trying to upgrade a stack of two GSM7352Sv2 switches to 10.0.0.31, so that I can add a M5300 to the stack. The switches crash on load when running the 10. firmware. I am basically trying to do o...
Marto731
Dec 09, 2013Aspirant
JPubcon,
Excuse me for replying 5 months after your post. This may help others.
You have to go to the last version on V8, specifically V8.0.3.34, before you can go to the first variant of V10.
There is a different boot code between V8.0.2.25 and V8.0.3.34
http://support.netgear.com/product/GSM7328Sv2
There is a detailed Word doc in release notes of V8.0.3.34,
which you will need to study closely.
Extract this from the code Zip.
http://downloadcenter.netgear.com/en/product/GSM7328Sv2
Regards Marto.
Regards Marto.
