jameswiltshire
Jun 06, 2019Aspirant
VLAN between different subnets
Hi,
I`m trying to connect to a vlan at a partners site but struggling and could do with some help.
Site 1
DrayTek 3900 Router
Netgear M4100-50G-POE+
IP address range: 10.0.10.1/24, VLAN 110 (Tagged)
vlan 100 (untagged) & vlan 110 (tagged)
Site 2
Cisco 3750X
IP address range: 10.23.31.0/24, VLAN 31 (Tagged)
vlan 100 (untagged) & vlan 31 (tagged)
Site 1 is connected to site 2 via a fibre with native vlan 100 (untagged) and vlan 110 (tagged)
We would like to connect to machines from site 1 (10.0.10.xx) to site 2 (10.31.31.xx) and visa versa.
Any help will be most welcome.
Thanks
James
1 Reply
- tagmeAspirant
Hi, what you need to do is just create a route entry on each side pointing to the other network with the routers outside address as a next hop. Do this over the untagged link and define a transder network like 192.168.168.0/24
Example
router site 1
IP route 10.23.31.0 255.255.255.0 192.168.168.10 (WAN address of site 2)
router site 2
IP route 10.0.10.1 255.255.255.0 192.168.168.20 (WAN address of site 1)
hope this helps
