SchoolTST
May 17, 2017Aspirant
VLAN Configuration
[This is a generic query on the function VLANs on Netgear switches, no specific switch model as I have to work with nearly all variations. Firmware can be updated I have no problem doin that, in the ...
- Jun 13, 2017
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
SchoolTST
Jun 07, 2017Aspirant
DaneA,
I had never heard of this variant of VLANs and that was a usefull excercise to read through. This may be possible but it means changing the default VLAN or at least removing the default VLAN from most of the switch ports to avoid cross communication on all the VLANs... obviously this leads to management issues when you need to remote in to the switch unless there is a dedicated management access port, I also think it will not be possible due to the nature of the WiFi access points as they require trunked VLAN ports.
I think the solution is going to have to include at least VLAN Routing and maybe the ACLs too. I have found that I should be able to configure both on the M4100-D12G switch according to the manual (I'm a bit sketchy when it comes to what is possible on certain Netgear Switches).
I did have trouble with the VLAN routing setup before when I last attempted it, but I am thinking that was caused by trying to setup VLAN interfaces subnetted within the range that was already set as the default VLAN interface (i.e. I didn't realise that the switch IP and subnet was not only the management interface but also the default VLAN interface) so I guess I was trying to subnet a subnet(!) and the switch didn't like that so gave me configuration errors.
Regardless of the issues, all the reading and advice has got me to the point were I am happy to purchase some APs and an M4100 switch and try to simulate what I have been discussing. I will Likely come back and mark one of your posts as an answered. I will however no doubt be posting a specific configuration issue cback here once I actually get down to configuration.
Regards
SchoolsTST
DaneA
Jun 07, 2017NETGEAR Employee Retired
Thanks for the feedback. About VLAN Routing, kindly access and read the article below because this would help:
VLAN Routing on NETGEAR Smart Switches
DaneA
