Arnaud_D
Nov 25, 2016Aspirant
Vlan routing interface down
Hello,
I have setvlan on my L3 switch, inter vlan routing is ok. Except for 1 vlan.
I have 2 vlans on the same port, both for wifi (business/guest) both of them worked fine last week, but now the business wifi vlan has his routing interface down
| Link State | Routing Interface Status |
| Link Up | Down |
All the vlan work fine, i tried to delete and create again the routing interface, but she's never up.
I tried to add a second port to the vlan and set the pc with static ip to ping the gateway, but still nothing, the interface stay down.
Any tips,
Thank you
1 Reply
- DanielZhangNETGEAR Expert
Hi Arnaud_D,
Welcome to NETGEAR community!:smileyhappy:
Could you please share us your "Logging buffer" after you delete and create IP address again?
Use this command "show logging buffered" on M5300 "Logging buffer".
Such as:
1) Delete IP address.
2) Disable Routing
3) Create IP address
4) Enable Routing
5) issue command "Show logging buffer" in Telnet/SSH session.
Anyway, The diagnostic files will help us to resolve your problem.
So Could you please share it to us as following guide?
How do I send diagnostic files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439
Daniel.
