gdelong
Apr 26, 2017Aspirant
VLAN TRunk betwen M4300 Stack and M4100-26G
I am trying to build a VLAN trunk between a new M4300 switch stack and a M4100-26G I can get default Vlan to pass traffic but nothing else There is now inter vlan routing configured The vlan...
gdelong
Apr 27, 2017Aspirant
See answers below
Could you please kindly answer the questions for VLAN trunking configuraiton as below?
For M4300 and M4100:
1. What is the 'Switchport Mode' on VLAN Trunking Configuration page? I have tried both Trunk and General, matching the ports on both switches for each try.
2. What is the 'Native VLAN ID' for the port? 1
3. What is the 'Trunk Allowed VLANs' for the port? I have tried 1,401 and the defaul 1-4093
4. It would be help if you can tell us your test topo. I have a 4 unit M4300 2x 52G, 1 X 26g and 1 X 26g poe+ Stack with 6 VLAN and use VLAN 1 as the defualt. I have multiple remote M4100 switches in IDFs. Right now just to try and get it working I am simply trying to pass VLAN 401 and 1. If I assign PVID 401 and VLAN 401 to a port it works as expected on the M4300 Stack.
Is it possible to just tell me how to properly configure a port on the M4300 and the M4100 to pas Vlan 1 the default and Vlan 401?
Retired_Member
Apr 27, 2017Hi dgelong,
Below is the answer for your question, hope it can helps!
For example: PC1 communicate with PC3 on VLAN1, PC2 communicate with PC4 on VLAN401
PC1/2-----(port1/2)M4100(port3)------(port3)M4300(port1/2)------PC3/4
Below is the configuration:
On M4100&M4300:
Port1: General mode, PVID=1, untag join to VLAN1 member(just default config)
Port2: General mode, PVID=401, untag join to VLAN401 member
Port3: General mode, PVID=1, untag join to VLAN1 member, tag join to VLAN401 member
EricZ
NETGEAR employee
- gdelongMay 01, 2017Aspirant
So as in my case that does not work what is the first couple of things to look at?
It is configured the way you say
Vlan 1 (untagged) works on remote switch and Vlan 401(tagged) does not
- Retired_MemberMay 01, 2017
Hi gdelong,
Could you please provide the configuration file of the two Switches, we can analysis further more.
How do I send configure files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/3143
9 EricZ
NETGEAR Employee
- Retired_MemberMay 03, 2017
Hi gdelong,
We have got your configuration file for two Switches. Thanks again!
Looks like there is no any problem for the configuration.
It's will be better if you could tell us the VLAN 401 traffic topo. from/to which port on M4100 and M4300?
