ChrisMayers
Mar 03, 2026Aspirant
Which Managed Switch Range?
Hi, Hopefully a very simple question. We are looking for 2 small managed PoE switches (ideally 1x8 port and 1x16 port). However, we're a bit confused by the various models and product ranges. Th...
ChrisMayers
Hi, Thanks very much for your reply! I did see these, and think they'll do the trick, but I was really hoping for something smaller than 24 port though as 16 is a bit bigger than we really need. Off the top of my head, I think there are about 12-14 connections required including the LAG connection back to the main switch... I've struggling to find anything between 10 ports and 24 ports with the necessary depth of configuration though. I guess having plenty of scope for expansion is never a bad things though...
Would anyone be able to post me a screenshot of a typical config screen for one of these - ideally the vLAN page. We need the more advanced vLAN settings that allow assigning of vLAN to LAGs, and also LAGs need to support LACP
Thanks again,
Chris.
- StephenBMar 03, 2026Guru - Experienced User
No screenshots (I have a different switch). But manual links might help:
- https://www.downloads.netgear.com/files/GDC/GS324TPv2/GS324TPv2_GS348TPv2_UM_EN.pdf
- https://www.downloads.netgear.com/files/GDC/GS310TPv2/GS310TPv2_UM_EN.pdf
