lissyx
May 19, 2023Aspirant
XS512EM firmware 1.2.0.5 and IGMP Snooping issues ?
Hello, I've been using a XS512EM switch for years (since 2019-07) as my core switch at home, running flawlessly. It has an Orange Livebox (5 then 6) connected for upstream FTTH, and links to a MS...
- Jan 29, 2024
So, while I would have loved too get a proper statement from some representative of Netgear on that issue, as of the 1.2.0.7 firmware, I have not been able to notice any of the symptoms I used to suffer from on 1.2.0.5, without any configuration change anywhere on my network.
Looking a the multicast packets reported by my UniFi switch, there no change while the screenshot above was clearly showing a difference.
lissyx
Jan 10, 2024Aspirant
Hello,
A few months later, I can confirm 1.2.0.5 was the root cause of my problem. I have failed to find time to properly investigate the issue, but 1.2.0.7 has just been released. I've pushed it on my switch and monitoring the situation. Hopefully even though the release note does not mention anything (there's the LLDP change but is it related?), this will help.
lissyx
Jan 29, 2024Aspirant
