leedenaro
Jun 27, 2017Aspirant
XS708T 10G/1000M Long Auto Negotiation
Hi guys, I have a XS708T 10G switch for communicating to 2-4 ethernet cameras at a time.The cameras can either be 10G enabled or 1G only, but i have noticed during the camera boot up, the auto ne...
XavierLL
Jun 27, 2017NETGEAR Employee Retired
Hi leedenaro
One of the reasons why the auto-negotitaion could take longer than expected is that you have some security mechanisms like STP or Port Authentication enabled in the swtich , so when you plug the cameras the switch also verify that the device will not introduce potential issues into your network.
Could you check that you don't have the SPT (Switching-SPT) enabled or any Port Security?
Hope it Helps
Xavier Lleixa
NETGEAR CBU PLM
- leedenaroJun 28, 2017Aspirant
OK ill take a look, where exactly would that be in the browser control window? the table with all the other port information/configuration?
- XavierLLJun 28, 2017NETGEAR Employee Retired
HI leedenaro,
You will see the information about the STP under:
And Port Authentication under:
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
