CALEYOCEAN
May 23, 2018Aspirant
10gb switch options
Hello All,
i am new to the forum, so forgive any errors i might make. I have inhirted a companies IT kit after a merger, so i am new to neatgear business products, i have used home products in...
- May 24, 2018
Hi CALEYOCEAN,
Welcome to our community! :)
That is a DAC or Direct attached cable used for stacking the switch. You may need to configure LAG in order for you to increase the throughput.
What are link aggregation and LACP and how can I use them in my network?
JohnC_V
May 24, 2018NETGEAR Employee Retired
Hi CALEYOCEAN,
- CALEYOCEANJul 06, 2018Aspirant
Thanks John. Much appreciate the link and info. I have 4xGS728TS(B)'s stacked via SFP, with LAG applied to 1 port on each switch, which connects to 4xGB nics in the server.
I hope that's the best way to get most throughput.
Regards Allan.
- JohnC_VJul 06, 2018NETGEAR Employee Retired
