PaulTaylor24
May 23, 2018Aspirant
10Gb Switch
Just looking for a basic non PoE 24-port 10Gb switch for desktop PC's. Any advise on a basic cost effective model to achieve this?
I have filled the Netgear call back form in over the last three days with no responce so trying this option.
Hi PaulTaylor24,
Welcome to the community! :)
Currently, there is no 24-port 10Gb Unmanaged Switch model. However, NETGEAR has a 5-port, 8-port and 10-port 10-Gigabit Unmanaged Switches. Check the following data sheets below:
If you really need a 24-port 10Gb switch, you may want to consider the XS728T switch which is a 10-Gigabit Ethernet Smart Managed Switch model. It has 24 1000/10GBase-T RJ-45 copper ports and it supports VLAN, LAG, network monitoring (SNMP), etc. Kindly check its data sheet below:
DaneANETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi PaulTaylor24,
- PaulTaylor24Aspirant
Thanks you
