sos100
May 24, 2016Aspirant
Adding a new GS724T switch via SFP Fibre connection
Hi - This is one of those "double checking I have this correct" queries. I have reviewed the other answers on the topic I can find in here, which have been helpful. We have a single Netgear...
- May 24, 2016
Hi sos100,
Welcome to the community! :)
What you are planning to do is correct. Both the AGM731F and the AGM732F are the modules that are compatible with the GS724Tv4. Refer to the table below:
DaneA
NETGEAR Community Team
JohnRo
May 27, 2016NETGEAR Employee Retired
Hello sos100,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
sos100
Jun 01, 2016Aspirant
Thanks - have done that now! Cheers, Sean
