davmerc1's avatar
davmerc1
Can ping everything on the internet but cannot access any webpage. Timing out
Hi.
I`m new to Netgear switches. Got a bunch of ProSafe GS728TPv2  that I have configured to be like this.
User PC (VLAN 10)-- VoIP Phone(VLAN20)--Firewall--Internet.
The Users which is in VLAN 10 has to connect to the LAN port of the VoIP phone (VLAN 20) to get IP address & have access to the internet which the 1st part is working fine. They are getting access to the Internet but all webpages are not loading & are timing out. Can ping 8.8.8.8 but cannot load any webpages. (Not DNS issue as webpage appears to load & takes a long time before timing out eventually). I`ve check on the firewall by connecting directly & everything is working fine there. No web filtering is configured yet. My guess is because of COS/DiffServ of the VLAN VoIP ? Hope you guys can help me !
Please find below the startup config file for the switch:
SYSTEM CONFIG FILE ::= BEGIN
! Model: GS728TPPv2
! System Description: NETGEAR 24-Port Gigabit PoE+ Smart Managed Pro Switch with 4 SFP Ports (GS728TPPv2)
! Firmware Version: 6.0.9.3 [Oct 28 2021 - 21:54:58]
! Loader Version: 1.0.0.5 [2017-12-28 09:35:22 UTC]
! Config Version: 0
! Hardware Version: 2
! System Name: 1st Floor Switch
! MAC Address: 80:CC:9C:E5:45:51
! Serial Number: 5WX716DE5084F
! System Up Time: 0 days, 0 hours, 12 mins, 48 secs
system name "1st Floor Switch"
system location "1st Floor"
system contact
web hidePopup lanOnly,
ip address 192.168.15.5 mask 255.255.255.0
ip default-gateway 192.168.15.254
no ip domain lookup
ip name-server 8.8.8.8
username "admin" secret encrypted tI46q63n0pWHFwAdxRcCzePOZsENg5+PjcNdqbZCOqY=
vlan 10
name "User_VLAN"
vlan 15
name "Management_VLAN"
vlan 20
name "VoIP_VLAN"
vlan 99
name "Native_VLAN"
vlan 4088
name "Auto-VoIP"
vlan 4089
name "Auto-Video"
management-vlan vlan 15
voice-vlan oui 0 0:1:0 SIEMENS
voice-vlan oui 1 0:3:0 CISCO1
voice-vlan oui 2 0:12:0 CISCO2
voice-vlan oui 3 0:60:0 NITSUKO
voice-vlan oui 4 0:d0:0 PINTEL
voice-vlan oui 5 0:e0:0 VERILINK
voice-vlan oui 6 0:e0:0 3COM
voice-vlan oui 7 0:4:0 AVAYA1
voice-vlan oui 8 0:1b:0 AVAYA2
spanning-tree mst configuration
name "80-CC-9C-E5-45-45"
lldp med network-policy 1 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 2 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 3 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 4 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 5 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 6 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 7 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 8 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 9 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 10 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 11 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 12 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 13 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 14 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 15 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 16 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 17 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 18 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 19 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 20 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 21 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 23 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy 24 app voice mode vlan-id val 20 cos disable auth enable dscp 0
lldp med network-policy enable voice
snmp user "admin" "AUTH" auth md5 encrypted tI46q63n0pWHFwAdxRcCzePOZsENg5+PjcNdqbZCOqY=
ip https
class-map "ClassVOIPVLAN" ipv4
match vlan 20
policy-map "PolicyVoIPVLAN"
class "ClassVOIPVLAN"
set queue 3
interface lag1
switchport hybrid allowed vlan add 20 tagged
switchport hybrid allowed vlan remove 1
interface lag2
interface lag3
interface lag4
interface lag5
interface lag6
interface lag7
interface lag8
interface lag9
interface lag10
interface lag11
interface lag12
interface lag13
interface lag14
interface lag15
interface lag16
interface g1
switchport hybrid pvid 10
switchport hybrid allowed vlan add 10 untagged
service-policy input PolicyVoIPVLAN
interface g2
interface g3
interface g4
interface g5
interface g6
interface g7
interface g8
interface g9
interface g10
interface g11
interface g12
interface g13
interface g14
interface g15
interface g16
interface g17
interface g18
interface g19
interface g20
interface g21
interface g22
switchport hybrid pvid 15
switchport hybrid allowed vlan add 15 untagged
description "Management Port"
interface g23
switchport hybrid pvid 99
switchport hybrid allowed vlan add 10,15,20 tagged
switchport hybrid allowed vlan add 99 untagged
description "Trunk Link to Core Switch01"
interface g24
description "Trunk Link to Core Switch02"
interface g25
interface g26
interface g27
interface g28
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    davmerc1,
    Welcome to the community!
    Try enabling domain lookup by typing "ip domain-lookup" on the CLI.
    For further assistance, you can open a support case here.
    JeraldM
    NETGEAR Community Team
    • davmerc1's avatar
      davmerc1
      Hi JeraldM
      Thanks for the reply.
      Apologies the model is GS728TPP. I believe there is no CLI on that model?
      • schumaku's avatar
        schumaku
        According to the config posted it's a v2
        ! Model: GS728TPPv2
        Since a recent firmware update, the Light CLI was added - consult the https://www.netgear.com/support/product/GS728TPPv2 FMI.
        However, the command JeraldM proposed (available typically on managed switches only) is to enable the DNS resolver on the switch management, allowing to use FQDNs e.g. for NTP servers, SNMP trap receivers, ... and has absolute no impact on the switch data traffic. On your current startup FWIW it's disabled by the "no ip domain lookup" - the control is on the DNS Configuration -> DNS Status [x] Disable Enable.
        From wally brain, there is no such control on the Light CLI.
        Connecting the PC direct to port 1..21, does it allow the Internet access as expected?
        Suspect there is some VLAN config inconsistency on your devices and network.
ProSupport for Business
