jolato
May 08, 2017Aspirant
Cant configure switch gs724t
I make a really error... :smileysad: I change the vlan id to manage the switch, and i cant connect to ip switch through web access... I dont know to connect the switch, because i cant find the cl...
- May 09, 2017
Hi jolato,
I am sorry but as I known we can only do a factory deafult by press the Factory Default Reset button on the front panel for more than one second to restore the factory default.
After do a factory default all current configurations would be erased. And if no dhcp server the management ip address would be 192.168.0.239.
Regards
Carl
Carl_z
May 08, 2017NETGEAR Expert
Hi jolato,
Welcome to the Community!
I think the trouble appear because we changed the management vlan id, but there is no port defualt to this vlan.
So can you think back wether you assign any port to the newly applied management vlan ?
If there is a port in the new management vlan and port pvid = management vlan, try to connect the mangement cable to the port .Then the switch would get back.
If there is not port in it. I hope you have a backup of configuration file. Then we could do a factory default then restore the configuration.
Regards
Carl
Netgear Employee
- jolatoMay 09, 2017Aspirant
Hi Carl.
I cant change the vlan of port because i dont entry in the switch, i havent a port with the same vlan of management. I have a big mistake... :smileysad:
this switch dont have other method to access the management??
Regards
- Carl_zMay 09, 2017NETGEAR Expert
Hi jolato,
Regards
Carl
