jolato
May 08, 2017Aspirant
Cant configure switch gs724t
I make a really error... :smileysad: I change the vlan id to manage the switch, and i cant connect to ip switch through web access... I dont know to connect the switch, because i cant find the cl...
- May 09, 2017
Hi jolato,
I am sorry but as I known we can only do a factory deafult by press the Factory Default Reset button on the front panel for more than one second to restore the factory default.
After do a factory default all current configurations would be erased. And if no dhcp server the management ip address would be 192.168.0.239.
Regards
Carl
jolato
May 09, 2017Aspirant
Hi Carl.
I cant change the vlan of port because i dont entry in the switch, i havent a port with the same vlan of management. I have a big mistake... :smileysad:
this switch dont have other method to access the management??
Regards
Carl_z
May 09, 2017NETGEAR Expert
Hi jolato,
Regards
Carl
