LathamsNick
Nov 01, 2022Tutor
Connect 2 Prosafe GS748TPS over 150m
Hi, I'm trying to determine the best way to connect 2 Prosafe GS748TPS over a distance of around 150m or so. I've determined over some of the posts here already that I need to get a couple ...
SapSteve
Sep 22, 2024Guide
Sorry to post this as an answer as it is really an on-topic question.
And when replying please don't point out the items referred to are end of life and recommend alternatives.
Currently I have two GS728TP switches, located in separate buildings, linked together via a 3x 1Gbs fibre LAG, thus in theory giving up to 3 Gbs connection speed and still maintaining 2 Gbs if a fibre path fails, the traffic between them includes a lot of continuous data streams from security cameras plus data duplication, hence just a single 1 Gbs link would cause performance issues. I currently use Finisar fibre SFP modules, these are tri-rated 1/2/4 Gbs, and operate perfectly at 1 Gbs when installed in the GS728TP (the use of the Finisars reduces spares inventory as they are also used, at higher speed, in fibre channel storage gear).
I am considering swapping the two GS728TP switches for two GS728TPS that I have been offered, to simplify administration by using the stacking feature. If successful, other switches at both locations may also be swapped out for stackable ones to create one centrally managed virtual switch..
Obviously the norm is to use short direct-attach cables to link the stacking ports, which according to the literature operate at 2.5 Mbs, so even with a single link, 2.5 Mbs will still be obtained between the switches.
Now to the root of the question - can the direct attach cables be replaced by fibre SFP modules? Thus allowing the switches to operate as a stack even though they are remote from each other.
And if so would the speed per stacking port be limited to 1 Gbs (the speed of the stacking port if it was configured as a standard ethernet port) or would a higher speed (2 Gbs ?) be attainable with a suitable SFP module? In my application a single 2 Gbs path would be fine but a single 1 Gbs path would not.
A long text I know - for which I apologise - but hopefully it makes my plan clear.
Thanks in advance for those reading it and hopefully submitting an answer.
Steve.
- ErwinLSep 23, 2024NETGEAR Moderator
Hello SapSteve
And welcome to the NETGEAR Community! 🙂
According to the datasheet, the GS728TPS supports up to 4 fiber or copper connections. You can configure them as a LAG (Link Aggregation Group) to achieve better speeds across the ports, as a single port will still be limited to 1G speed, even on a fiber link
https://www.downloads.netgear.com/files/GDC/datasheet/en/GS728TS-GS728TPS-GS752TS-GS752TPS.pdf
Have a lovely day,
Erwin
Netgear Team- SapSteveSep 23, 2024Guide
Thanks for that, but I am already using 3x 1Gbs fibre paths in a LAG as my existing configuration, the only problem is that when I change configurations (especially those of VLANs) I need to log into and change settings on both switches, this should theoretically be easier if switches capable of stacking were used and thus behaved as a single virtual switch.
The fundamental question was that can GS728TPS switches be stacked with the relevant stacking ports populated with fibre tranceivers rather than by using a direct attach cable? And if it is possible and only a single connection existed would that be limited to 1Gbs rather than the 2.5Gbs allowed by using a direct attach cable, even if the fibre tranceiver module was capable of speeds higher than 1 Gbs, I assume it could be as none of your approved SFP fibre modules are rated for greater than 1Gbs and hence faster modules may not be supported even though the stacking ports themselves are obviously cable of 2.5Gbs.
- ErwinLJan 05, 2025NETGEAR Moderator
Your GS728TPS can be stacked. You may refer to the manual from page 7 onwards from the link below. You have option of two stacking ports to connect and these can be LAG for wider bandwidth. It is recommended to use direct attach cable AGC761 for stacking and for the supported SFP modules are the following:
AGC761 ---1m 1G/2.5G Direct Attach SFP Cable
AGM731F --1000BASE-SX SFP GBIC
AGM732F --1000BASE-LX SFP GBIC
AFM735 --100Base-FX SFP LC GBIChttps://www.downloads.netgear.com/files/GDC/GS728TPS/GS7xxTS_TPS_HIG_18Jan2012.pdf
Have a lovely day,
Erwin
Netgear Team
