kazimates
Nov 02, 2018Follower
connecting NG-GS752TP swithes on C5G124-48P2 and pcs over phones
I need to approve if NG-GS752TP can be work properly for given example below.
I had 16 servers and AD with DHCP srole on it. DHCP server has a 6 different VLANs on it.
This 16 servers ne...
- Nov 05, 2018
Hi kazimates,
Welcome to our community! :)
As per checking, Samsung SMT-i3100 supports 802.3af POE on which is supported also by the GS752TP switch. It also supports Auto-VOIP and Voice VLAN that makes it easier to setup with VOIP phones. In addition, some NETGEAR business-class products include 90 days of technical support via phone and lifetime support through online chat.
You may check the warranty terms here. If you have questions, please let me know.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Nov 05, 2018NETGEAR Employee Retired
Hi kazimates,
