bscaz's avatar
bscaz
Initiate
May 05, 2017
Connecting XS7xxT with GS7xxTS with AXC761 DAC
Hello Netgear community,
We have a 10G XS712T switches and a new 3 x GS752TX stack.
Can we use AXC761 DAC to connect the XS712T with the GS752TX stack ?
If not, any suggestions of other options we could try.
Thanks in advance,
bscaz
  • HI bscaz,
    Welcome to our community!
    Yes you can use the AXC761 to to the interconnection , the only think is that please make sure that the GS752TX ports are configured in Ethernet mode and not Stacking mode.  You can check it under the Stacking Menu on the System Tab:
    Moreover you can use 2xAXC761 and configure a LAG between the GS752TX and the XS712T so you can have redundant uplinks.
    Hope it Helps!
    Xavier Lleixa
    NETGEAR CBU PLM
1 Reply
  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    HI bscaz,
    Hope it Helps!
    Xavier Lleixa
    NETGEAR CBU PLM
ProSupport for Business
