smudgebutter
Apr 02, 2018Aspirant
Convert GS108Tv2 to unmanaged?
Our IT security setup is being changed from using to two GS108Tv2's as firewalls to another device plus an unmanaged switch. My question is - Can I configure (or un-configure) this managed switch to use as an unmanaged switch rather than toss it out and buy the GS108 unmanaged switch. Seems such a waste.
Welcome to the community!
I think your ideal can work. Just clear the current configurations of GS108Tv2(you can perform a factory default)
If there any other issue when using it please keep us informed
Thanks
Carl
Netgear Employee
- Carl_zNETGEAR Expert
Thanks
Carl
Netgear Employee
- smudgebutterAspirant
Thank you. We will give that a go and see if it works as expected then. Much better solution than toss and replace.
- schumakuGuru - Experienced UserIt still remains a manageable switch. Your IT security seems to prefer an unmanaged switch to minimise the number of potential attack vectors. Not sure this is the right way to go, but that's another discussion.
