mcgroarty1
Nov 13, 2016Aspirant
Difference between v3 and v4 of GS724T
What is the difference between the v3 and v4 of the GS724T switch? Amazon has both, although the v4 is not available from as many sellers and has a higher price. I also found a page that warns v3...
- Nov 14, 2016
Hi mcgroarty1,
A. The GS724Tv4 supports the following features below while the GS724Tv3 does not.
1. Dynamic VLAN Assignment
2. Energy Efficient Ethernet (IEEE 802.3.az)
3. MLD (Multicast Listener Discovery) Snooping
4. DHCP snooping
5. Dynamic ARP Inspection
6. Multicast VLAN Registration (MVR)
7. Multiple Registration Protocol (MRP)
B. Other differences between GS724Tv4 and GS724Tv3:
1. The GS724Tv4 has a MAC Address database size of 16k while the GS724Tv3 has only 8k.
2. The GS724Tv4 supports IGMP Snooping v1/v2/v3 while the GS724Tv3 supports IGMP Snooping v1/v2 only.
3. The GS724Tv4 has a flash memory size of 32MB while the GS724Tv3 has 16MB.
4. The GS724Tv4 has a 128 MB DDR2 SDRAM while the GS724Tv3 has 16 MB DDR.
DaneA
NETGEAR Community Team
DaneA
Nov 14, 2016NETGEAR Employee Retired
Hi mcgroarty1,
4. DHCP snooping
DaneA
mcgroarty1
Nov 14, 2016Aspirant
Thank you. I ended up finding another seller who had the v4 at slightly less than the Amazon price for the v3. The additional memory and lower power consumption are worth enough to go out of my way for the newer model.
I assume there's nothing to the claim that the v3 and v4 cannot coexist on the same network? I saw that here:
https://support.biamp.com/Tesira/AVB/Identifying_Netgear_GS724T_switch_version
