mmagongoa
Mar 10, 2017Aspirant
Firmware version 5.0.0.8 issues
Hi. I have a Netgear FS728TP switch that had firmware v 3.0.0.x. So i decided to upgrade to version 5.0.0.8 using the Smartwizard Discovery tool. After a successful upgrade, the issue i have now is...
- Mar 13, 2017
Hi DaneA,
thanks for the reply. Here are some of the answers to your question.
a. Version 3.0.0.22
b. I didn't upgrade the boot code to 1.0.0.5
c. I pressed the factory default, and still didn't work
I followed the steps below a couple of times and still doesn't work. The PoE Max light is still orange.
Thanks.
Maphuti
DaneA
Mar 13, 2017NETGEAR Employee Retired
Since the steps didn't help, I suggest you to open an online case with NETGEAR Support at anytime. Kindly state your concern about the FS728TPv1 switch you have. Attach a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of the FS728TPv1 switch to the online case for warranty verification. If the hardware warranty is valid, an online replacement will follow.
DaneA
NETGEAR Community Team
mmagongoa
Mar 13, 2017Aspirant
Will do, thanks DaneA.
Maphuti
