Edunishi's avatar
Edunishi
FS728TPv2 MIB files. Enable/disable POE admin mode via NMS300
Hi,
We currently have 50 FS728TPv2 switches and are used to power electronic locks. We would like to know if there is a MIB file for the FS728TPv2 where it would be possible to cut the POE of a specific port via SNMP. I saw there are a few private netgear MIB's on NMS300, but none of them worked. I've also googled around but nothing came up.
Any help would be apreciated.
Thanks,
  • Edunishi,
    I just want to follow-up on this.  Were you able to download the FS728TPv2 MIBs?  If yes, does it include the specific MIB where it would be possible to cut the POE of a specific port via SNMP?
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Edunishi,
    Welcome to the community! :)
    You can download the FS728TPv2 MIBs on this link.  The link will expire within 48 hours.  Check if the FS728TPv2 MIBs includes the specific MIB where it would be possible to cut the POE of a specific port via SNMP
    DaneA
    • DaneA's avatar
      DaneA
      Edunishi,
      DaneA
ProSupport for Business
