parky_dw
Nov 10, 2016Aspirant
GS105Ev2 Logon issues
I've just got hold of a GS105Ev2. After presssing the factory reset button it appeared on my LAN. My problem is that I can't log on to it. I downloaded and installed the ProSafe Plus Configurat...
- Nov 10, 2016
Well I was a little premature here and I've now sorted out my problem.
With the Configuration Utility, in the first release it looks like clicking on the found switch was sufficient to select it and bring up the passsword prompt - as shown on various u-tube videos. With later releases of the firmware, clicking on the switch (double or single) only highlights the entry. You then need to click on APPLY to actually open it. (I'm so used to double-click on something to select it....)
I'm not too sure what the web interface logon problem was - it may be because the switch was running the original firmware there wasn't much in the way of web support in there if any? Anyway,having logged on via the Configuration Utility and updated the firmware to the latest release all is fine on that front.
David
parky_dw
David
- DaneANov 10, 2016NETGEAR Employee Retired
Hi parky_dw,
Welcome to the community! :)
I'm glad that you were able to update the firmware. Be reminded that it is recommended to perform a factory reset after upgrading the firmware of the switch then reconfigure it from scratch.
About accessing the web-GUI of the GS105Ev2, it seems that the GS105Ev2 is still in its default IP Address. Kindly try the steps below:
1. Disconnect the GS105Ev2 from the existing network.
2. Connect a PC to a LAN port of your GS105Ev2.
3. Set a static IP address of 192.168.0.210 to your PC.
4. Open a browser like Google Chrome. Then, at the address bar of it, type 192.168.0.239 then press Enter. Login to the web-GUI of the GS105Ev2. Enter "admin" as the username and "password" as the password without the quotation marks.
Note: The default IP address of GS105Ev2 is 192.168.0.239.
5. The Switch Information page displays. In the DHCP mode menu, select Disable. Then, enter the IP Address, Subnet Mask and Default Gateway that corresponds to your existing network. Then, click Apply.
Note: You will lose access to the web-GUI of the GS105Ev2 because you have just change its IP Address which is normal.
6. Connect a LAN port of the GS105Ev2 to your router.
7. Set your PC to "Obtain an IP Address Automatically." Then connect it to a LAN port of the GS105Ev2.
8. Open a browser like Google Chrome. Then, at the address bar of it, type the static IP Address you have set to the GS105Ev2 then press Enter. If you are able to access it, then it means that the GS105Ev2 is now a part of your existing network.
Note: You may also perform a connectivity test. Open command prompt on your PC then ping the static IP address you have set to the GS105Ev2 (for example: ping 192.168.1.18 then press Enter). If you receive replies then it means that the GS105Ev2 is reachable within your existing network.
DaneA
NETGEAR Community Team
- parky_dwNov 10, 2016Aspirant
Hi Dana,
Thanks for the reply, but the first factory reset put it into DHCP mode so it was on my subnet. The issue I had before updating the firmware was that I couldn't logon to the web interface using the default username of "admin" and the default password of "password". (I was getting the username/password prompt from the GS105E).
In view of your response just thought I'd add a bit of info for others in a related situation. (Your steps 3 and 7).
I've recently been playing with various bits of hardware where the default is to come up at a fixed IP address that isn't on my subnet (192.168.10.x).
For example if the item defaults to 192.168.0.210.......
With Windows (I'm running 10) open an administrative command line window and type:
netsh interface ipv4 set address name="ethernet" static 192.168.0.4
to switch to an arbitrary IP address in the new subnet. In hte above example I picked on ".4"
Do your stuff with a browser pointed at 192.168.0.210 then:
netsh interface ipv4 set address name="ethernet" dhcp
will reset your ethernet address back to normal (assuming you're running with DHCP).
Anyway you get the idea.
David
