bgabriels
Mar 11, 2017Initiate
GS105PE - PoE pass through not working until hard reset
Regarding: https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS105PE-PoE-pass-through-not-working-until-hard-reset/td-p/1109432 I'm facing the same issue as in this topic, but it doesn't...
- Mar 14, 2017
Fixed by Customer support with Beta Firmware
RenegadeTech
Jul 20, 2017Aspirant
For the record, I'm having the exact same problem as stated in this topic as well as the linked one when powering the GS105PE with an HPE OfficeConnect 1920 PoE+ switch (provides up to 30W per port,) except I can't get my Netgear GS105PE to *ever* show a green PoE light on port 5 or provide power to the PSE ports but for half a second at start-up. Latest firmware loaded (V1.5.0.4) and factory reset performed with no effect.
I'm on hold with tech support now...
JohnC_V
Jul 20, 2017NETGEAR Employee Retired
Hi RenegadeTech,
It seems that this post is too old already. Please create a new thread for this issue.
- Feb 22, 2022Retired_Member
