zamb
Oct 20, 2018Guide
GS105PE - PoE Passtru works only after Reset-button pressed
I have a GS105PE, it is powered by a UniFi Switch 8 POE-60W, 802.3af.
Then I passtru to a UniFi AP-AC-LITE. I have to push the netgear reset button to get PoE passtru work and the AP are powered up...
- Mar 13, 2019
Hi Sam,
I got your AP today and it shows class 4.
Therefore, it's correct behavior that it can't be power up by GS105PE in your case since GS105PE is powered by 802.3af PSE.
In your case, if you want your AP can be powered up by GS105PE, please connect 802.3at PSE to GS105PE PD port.
