Fanagolo's avatar
Sep 10, 2026
GS108Ev3 refuses to connect
I have 4 GS108Ev3 switches. As they are all configured and working well I don't need to administer them often. Today I wanted to login to them - and can't.   All 4 refuse to connect when I acces...
  • schumaku's avatar
    schumaku
    Sep 11, 2026
    Here what Tailscale says about such issues:
    https://tailscale.com/docs/reference/troubleshooting/network-configuration/tcp-connection-two-devices
    Packet size limits can also cause connection problems on certain types of networks.
    Tailscale uses a maximum transmission unit (MTU) of 1280. If there are other interfaces which might send a packet larger than this, those packets might get dropped silently. These can be verified by using tcpdump.
    The limitation in your use case isn't (only) Tailscale.
    It's much more the very simple IP stack "glued on" to the GS108Ev3, and many more Plus resp. Easy Smart switches not built in a real managed switch core, therefore not supporting PMTUD (Path MTU DIscovery), and not allowing MTU smaller but the default 1500.
    The ubiquitous ICMP Ping check not allowing fragmentation does show the effective path MTU limit
    PS C:\> ping 10.10.1.176 -f -l 1472
    Pinging 10.10.1.176 with 1472 bytes of data:
    Reply from 10.10.1.176: bytes=1472 time=8ms TTL=64
    Reply from 10.10.1.176: bytes=1472 time=2ms TTL=64
    Reply from 10.10.1.176: bytes=1472 time=3ms TTL=64
    Ping statistics for 10.10.1.176:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 2ms, Maximum = 8ms, Average = 4ms
    But beyond:
    PS C:\> ping 10.10.1.176 -f -l 1473
    Pinging 10.10.1.176 with 1473 bytes of data:
    Packet needs to be fragmented but DF set.
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
ProSupport for Business
