Dave40
Oct 22, 2016Aspirant
GS108Tv2 port flapping
I have sky Q running on Ethernet. Using 2 netgear switches on 5.4.2.22 there is no problem. However, I installed 5.4.2.25. when both switches reboot and activate the new firmware the highly active sky...
- Oct 30, 2016
0 1 days 21:36:23 Link Up: g7 1 1 days 16:00:48 Link Up: g8 2 1 days 16:00:45 Link Down: g8 3 1 days 16:00:36 Link Up: g8 4 1 days 16:00:33 Link Down: g8 5 1 days 16:00:27 Link Up: g8 6 1 days 13:53:42 Link Down: g8 7 0 days 21:41:28 Link Down: g7 This was from 251 which is connected directly to the Main Sky Q box port 8 (port 7 is the TV). I suspect that their is a minor issue with the Q box. Overall everything has been stable. 252 has not shown any port flapping or link changes in 24h.
Upon reset to defaults on Friday, I noted a log that stated something like 'settings not compatible with current firmware'. Sadly I didn't capture that message.
Conclusions
I started out upgrading initial fw to .18 with a reset to defaults back then, then .19 about a year ago then .22 a few months ago. Since the reset to defaults on fw .25 and the reprogramming of both switches, both have been perfectly stable. The .25 firmware appears to require a reset to default, atleast when coming from so many older baselines. I now consider the case closed.
Dave40
Oct 28, 2016Aspirant
I've managed to try .25 with a factory reset and all appears OK. I'll update this post on Sunday as that should be sufficient time to check for issues.
Thanks
Thanks
- Dave40Oct 29, 2016Aspirant
3 0 days 14:58:47 Link Up: g3 4 0 days 14:58:44 Link Down: g3 5 0 days 14:58:43 Link Up: g3 6 0 days 14:58:40 Link Down: g3 7 0 days 14:58:39 Link Up: g3 8 0 days 14:58:36 Link Down: g3 9 0 days 14:58:35 Link Up: g3 10 0 days 14:58:32 Link Down: g3 11 0 days 14:58:31 Link Up: g3 12 0 days 14:58:28 Link Down: g3 13 0 days 14:58:26 Link Up: g3 14 0 days 14:58:23 Link Down: g3 15 0 days 14:57:21 Link Up: g3 16 0 days 14:57:18 Link Down: g3 17 0 days 14:38:50 Link Up: g3 18 0 days 14:38:47 Link Down: g3 19 0 days 14:38:45 Link Up: g3 20 0 days 14:38:43 Link Down: g3 21 0 days 14:38:41 Link Up: g3 22 0 days 14:38:38 Link Down: g3 23 0 days 14:31:29 Link Up: g3 24 0 days 14:31:26 Link Down: g3 25 0 days 14:09:45 Link Up: g3 26 0 days 14:09:42 Link Down: g3 27 0 days 13:53:45 Link Up: g3 28 0 days 13:53:42 Link Down: g3 29 0 days 13:45:11 Link Up: g3 30 0 days 13:45:08 Link Down: g3 31 0 days 13:32:54 Link Up: g3 32 0 days 13:32:51 Link Down: g3 33 0 days 13:30:11 Link Up: g3 34 0 days 13:30:08 Link Down: g3 - Dave40Oct 29, 2016Aspirant
<13> Oct 29 04:28:26 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 254 %% Link Down: g3 <13> Oct 29 04:28:29 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 255 %% Link Up: g3 <13> Oct 29 04:28:30 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 256 %% Link Down: g3 <13> Oct 29 04:28:33 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 257 %% Link Up: g3 <13> Oct 29 04:28:34 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 258 %% Link Down: g3 <13> Oct 29 04:28:37 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 259 %% Link Up: g3 <13> Oct 29 04:28:38 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 260 %% Link Down: g3 <13> Oct 29 04:28:40 192.168.50.252-1 TRAPMGR[2177210636]: traputil.c(605) 261 %% Link Up: g3 - Dave40Oct 29, 2016Aspirant
<14> Oct 29 10:55:33 192.168.50.252-1 SNTP[2184296428]: sntp_client.c(1806) 1 %% SNTP: system clock synchronized on Sat Oct 29 10:55:32 2016 UTC+00:00 <14> Oct 29 10:59:19 192.168.50.252-1 NIM[2179216468]: usmDbIntfTypeGet(1573) 2 %% internal interface number 0 out of range <14> Oct 29 10:59:19 192.168.50.252-1 NIM[2179216468]: usmDbIntfPhyCapabilityGet(1656) 3 %% internal interface number 0 out of range <14> Oct 29 10:59:35 192.168.50.252-1 NIM[2179216468]: usmDbIntfTypeGet(1573) 4 %% internal interface number 0 out of range <14> Oct 29 10:59:35 192.168.50.252-1 NIM[2179216468]: usmDbIntfPhyCapabilityGet(1656) 5 %% internal interface number 0 out of range
