Dave40's avatar
Dave40
GS108Tv2 port flapping
I have sky Q running on Ethernet. Using 2 netgear switches on 5.4.2.22 there is no problem. However, I installed 5.4.2.25. when both switches reboot and activate the new firmware the highly active sky...
  • Dave40's avatar
    Dave40
    Oct 30, 2016
    01 days 21:36:23Link Up: g7
    11 days 16:00:48Link Up: g8
    21 days 16:00:45Link Down: g8
    31 days 16:00:36Link Up: g8
    41 days 16:00:33Link Down: g8
    51 days 16:00:27Link Up: g8
    61 days 13:53:42Link Down: g8
    70 days 21:41:28Link Down: g7
    This was from 251 which is connected directly to the Main Sky Q box port 8 (port 7 is the TV).  I suspect that their is a minor issue with the Q box.  Overall everything has been stable.  252 has not shown any port flapping or link changes in 24h.
    Upon reset to defaults on Friday, I noted a log that stated something like 'settings not compatible with current firmware'.  Sadly I didn't capture that message.
    Conclusions
    I started out upgrading initial fw to .18 with a reset to defaults back then, then .19 about a year ago then .22 a few months ago.  Since the reset to defaults on fw .25 and the reprogramming of both switches, both have been perfectly stable.  The .25 firmware appears to require a reset to default, atleast when coming from so many older baselines.  I now consider the case closed.
ProSupport for Business
