thatguymoon's avatar
thatguymoon
GS110EMX: 10G ports throttle uploads to 250-300 Mbps
I've been going back and forth with Netgear support for over a week about this and I'm honestly at a loss. I'm hoping someone here can tell me if I'm crazy or if what they're telling me doesn't make sense, because it really doesn't add up to me.
My Setup
  • Switch: Netgear GS110EMX (firmware 1.0.2.8)
  • Port 1: Internet uplink (1G, connected to router — standard fiber ISP)
  • Port 9: Mac Pro via OWC Thunderbolt 4 to 10G Ethernet Adapter
  • Port 10: Asustor AS6508T NAS (10G)
  • Cables: Cat6A throughout
This is exactly why I bought this switch — two 10G ports for my computer and NAS, with everything else on the 1G ports. Pretty standard home prosumer setup.
The Problem
Internet uploads are throttled to about 250-300 Mbps when my computer is on a 10G port. Downloads are fine at 830-880 Mbps. When I move the same computer to a 1G port with the exact same cable, uploads jump to 708 Mbps. That's more than double the speed on a port that's supposedly 10x slower.
What I've Tested (at Netgear's request)
I ran every test their L3 support team asked for. Here are the results:
Internet Speed Tests (computer on 10G port 9):
Flow ControlDownloadUpload
OFF865 Mbps306 Mbps
ON (port 9 only)879 Mbps169 Mbps
ON (both 9 & 10)820 Mbps137 Mbps
Internet Speed Test — computer on 1G port (same cable, same everything):
DownloadUpload
884 Mbps708 Mbps
iPerf3 between Mac and NAS (local, 10G ↔ 10G):
DirectionSpeed
Mac → NAS3.73 Gbps
NAS → Mac9.40 Gbps
Local 10G performance is excellent. The ports, cables, and NIC all work fine.
What Netgear Says
After all this testing, support came back and told me:
  1. This is "working as expected" and "within the design limitations of the switch"
  2. The 10G ports are "intended to be used as uplinks" — not for client devices
  3. A replacement would behave the same way
  4. My configuration is "not the intended use case"
Why I'm Confused
I don't understand how any of this is "expected behavior." Specifically:
  • How does a 1G port give me faster uploads than a 10G port? If the 1G uplink is the bottleneck, moving to a slower port should give me equal or worse speeds. Not more than double. Nobody has explained this.
  • Why are only uploads affected? Downloads through the 10G port hit 865 Mbps — nearly saturating the 1G uplink. The traffic crosses the same 10G/1G speed boundary in both directions. Why would only one direction have "buffer overflow" problems?
  • Flow Control made things WORSE. They asked me to enable it. It dropped uploads from 306 Mbps to 137 Mbps. How is that a fix?
  • The product page says "No Network Bottlenecks thanks to the 2 10-Gigabit/Multi-Gigabit Uplinks." Now support says those ports are only meant to be uplinks and my setup is unsupported. The user manual literally shows 10G client devices connected to ports 9 and 10 in its network diagrams.
  • This switch used to work. I used the exact same setup with fiber in Chicago for years with no issues. I only noticed the problem after switching to fiber here in LA recently. Something changed.
What I'm Asking
Has anyone else seen this? Am I wrong to think a managed switch should be able to handle 10G devices sending traffic through a 1G uplink without losing 70% of the uplink's capacity? I've seen a couple other threads about similar issues with the GS110EMX and I'm starting to think this is a known design flaw that Netgear just doesn't want to acknowledge.
At this point I just want to know if I should keep fighting for a replacement or just give up and buy a different switch.
Any insight would be really appreciated. I've spent way too many hours on this already.
  • FURRYe38's avatar
    I have the MX version of the GS switch in my network A few years ago I found an issue with an Apple TV causing problems when how i had the MS switch connected to my XS 10Gb switch. Seems to be similar situation here. Once I changed the uplink between the host router, XS505M and GS switch, everything has been working as expected and speed between the GS and XS switches remains at 10Gb and have see no drastic drops in speed.
    Host router 2.5Gb port > XS505M Ethernet port > XS505M SFP to ethernet 10Gb port > GS110MX 10Gb Ethernet port <>GS110MX 1Gb>< ATV works
    Similar seen in the IG for the MX switch I have:
    https://www.downloads.netgear.com/files/GDC/GS110MX/GS110MX_IG_EN.pdf
    Though mines connected with it's 10Gb port to the SFP port on the XS switch.
    The EMX doesn't really show how it's 10Gb is used in it's IG:
    https://www.downloads.netgear.com/files/GDC/GS110EMX/GS110EMX_IG_EN.pdf
    I see from the EMX spec sheet there are some differences:
    Pre-Defined Rate Limiting Rates: 1/5/10/50/100/500 Mbit/s
    https://www.downloads.netgear.com/files/GDC/GS110EMX/GS110EMX_GS110MX_DS.pdf
    Not sure how impactful this could be with the EMX.
    The support site for the EMX and MX switches both say "GS110EMX - 8-Port Gigabit Ethernet Plus Switch with 2 Port 10G/Multi-Gig Uplinks"
    So you may need to configure the switch for it's designed intended use for the 10Gb port. These seems to have this particular configuration requirement here.
    Has a reset been performed on it and setup from scratch?
    Be sure to use good quality LAN cable. CAT6A STP is recommended for connections 2.5Gb or higher.
  • Thanks — QoS rate limits are confirmed not set, factory reset has been done, and I'm using Cat6A cables. My iPerf results at 9.4 Gbps locally confirm the cables and ports are working fine. Sounds like you ran into the same core issue and solved it by adding a 10G switch upstream. I shouldn't need a $250 workaround for a switch that's supposed to handle mixed speeds though.
    • FURRYe38's avatar
      For my issue, I already had both switches in house. It was the unknown operation and configuration and assuming that the ports would work in the initial any configuration and failed.  The host routers port was going to the SFP port on the XS switch, then from here, 10Gb ethernet port was doing down to the MX 10 Gb port. Apple TV was connected on the 1Gb port on the MX switch. After someone said there was a problem after using the Apple TV streaming that was connected at the MX switch. Found all devices on this segment with out IP addresses or internet services. Any streaming on the ATV would cause this network segment to fail entirely. After troubleshooting then swapping around were the host router connected and using the SFP port on the XS switch for the uplink to the MX switch to it's 10Gb port. Problem solved. Zero issues since.
      I also use these switches for Orbi system ethernet backhaul connections when needed. All that works too.
      Seems that NG has these partcular switch ports used for specific uplink configurations and not for any general use. So you may need something upsteam for more geneal port usage if you need better port operations. The XS505M is solid and works well. All it's ethernet ports are up to 10Gb supporting. I added the SFP adapter to add one more 10Gb port that I needed. And I see it also mentions the SFP port being the uplink or core backbone so kinda makes sense that it works correctly with the MX switch on it's 10Gb port.
    • StephenB's avatar
      FWIW, I agree.
  • schumaku's avatar
    schumaku
    Fix One-Way Slow Traffic (TSO Bug)?
    If you experience fast download speeds but extremely slow upload speeds over Thunderbolt/Ethernet, it is likely due to a bug in how macOS handles TCP Segmentation Offload (TSO).
  • schumaku's avatar
    schumaku
    Thath's the system you see the not maximal performance? Wasn't there a discussion a longer time ago, that M1 Thunderbolt ports don’t fully support USB 3.1 Gen 2?
    Apple claims that all its new models using M1 series chips come with Thunderbolt ports which support “USB 3.1 Gen 2 (up to 10Gb/s)”. However, many users have reported performance which doesn’t reach 10 Gb/s for directly connected external disks. This article examines why performance experienced by users falls short of Apple’s claim.
    • StephenB's avatar
      thatguymoon​:  You can test this possibility by connecting the Mac directly to the NAS (no switch) and setting up compatible static IPs on both the NAS and the Mac.  Then measure throughput using iperf3.
ProSupport for Business
