egnlsn's avatar
egnlsn
GS305E and VLANs
I'm trying to get a GS305E switch configured for VLANs.  The VLANs at the port on the router to which this switch is connected are 5 (main one) and 7.  I need to configure this switch so that VLAN 7 is the only one available at ports 2-5.
Thanks for any help!
  • schumaku's avatar
    schumaku
    So simple access ports on 2..5 or VLAN 7, while port 1 serves as uplink for VLAN 5 and VLAN 7. Should the uplink carry both VLAN in a tagged trunk, or is the uplink intended to carry the VLAN 5 as untagged?
    Is the router port where you are connecting the uplink carrying the main VLAN 5 as untagged (also serving as the management VLAN), while the VLAN 7 is there as a tagged?
    Keep in mind the uplink port post be configured the same way as your primary router port...
  • I can get into the management page just fine.  If I made the router's port VLAN 7 only, how would I manage the switch?
  • StephenB's avatar
    Is the issue that you can't get into the web management page?  Or that you need help with the config  once you get there?
    Then why are you bringing VLAN 5 to the switch?
    If all the client ports on the GS305E are on VLAN 7 then you actually don't need to set up VLANs at all on this switch.  All you need to do is to connect to an upstream switch/router port that is untagged and only in VLAN 7.
ProSupport for Business
