sebr
May 30, 2022Aspirant
GS305EPP compatibility issues?
Hello, my home setup currently involves a GS108PE in the basement that powers two switches (GS108Tv2 & GS105PE) in the attic via PoE. There is about 15m Cat.7 installation cable and a patch panel at...
schumaku
May 30, 2022Guru - Experienced User
sebr wrote:
Now I replaced the
GS308EGS108PE (??) with a GS305EPP and the switches in the attic (GS108Tv2 & GS105PE) do not power up.
Does not sound wrong - especially with direct cables powering each of the two individually.
Are there complere four pair (eight strand) cables installed?
- sebrMay 31, 2022Aspirant
Sorry but i forgot to mention that the cable from basement to the attic is Cat7 duplex cable (eight strand), so actually two cables.
And yes, you are right: the old switch was GS108PE 🙂
