ckruijntjens
Mar 26, 2026Guide
GS308EPP new firmware 2.0.0.11 bug?
Hi all,
I updated my firmware from 2.0.0.5 to 2.0.0.11 on 2 of 4 switches. On both switches i can not acces the web ui, And the switch is not responding on ping....
Anyone else having the...
- Mar 28, 2026
ckruijntjens wrote:
I have 4 switches connected to each other. All ports are using vlan and trunk ports.
Hello Chris,
First tell us a little bit more about your network. Understand you have a series of VLANs, all different from VLAN VID 1. And all are connected over direct Ethernet links, acting as a trunk. With each VLAN configured [T]agged.
ckruijntjens wrote:
If i put a port to pvid1 i can access the management webui. However i do not use this (Pvid1) i use different pvid config.
This makes the computer you are connecting (without a special VLAN config) assigning all frames -from- the connected device to the VLAN 1 on your network:
Is the same port also configured to participate in the VLAN 1?
Can you reach all switches over this VLAN 1, or do you have to repeat this on each switch?And since the intro of 2.0.0.11 on the GS308EPP/GS308EP (or 2.0.0.10 on GS305EPP/GS305EP) - introducing a Management VLAN - you can no longer ping or reach these nice switches anymore. What system or router had delivered the IP config before? On which VLAN did this happen?
Before the update, these switches were connected "flat" direct to a (V)LAN like a mobile phone on the Wi-Fi, connecting to a certain SSID. I assume there is no specially configured multi-SSID and VLAN capable wireless access point, where the SSID would be associated to a certain VLAN - the uplink from the AP does make up a trunk with tagged VLAN(s). When you use a wireless device (like a PC), you usually got an IP address. Does this IP and subnet come from your ISP router, or from a security appliance, a bigger, more complex multi VLAN and multi-subnet capable device?
This subnet - likely operated on one of your VLANs - is what you use as your Management Network!
All you have to do now is define that specific Management VLAN VID on the switch in the Advanced Dot1Q config. Now the switch(es) Management interface is yon the VLAN you desire, and no longer on the VLAN with the VID 1.
If everything is working after that, remove the ports where you had temporarely defined the PVID 1 from the VLAN 1.
You still have not answered my question if the field for the Management VLAN is empty (probably causing the problem!), or if there was a number configured.
Happy Saturday!
-Kurt
RobMendi
Mar 27, 2026Aspirant
I am having the same issue on two switches. All was fine under 2.0.0.5 and now that I have updated them to 2.0.0.11, I cannot see the web UI to login. Did anyone find a solution?
schumaku
Mar 28, 2026Guru - Experienced User
Before 2.0.0.11 (GS308EP/EPP) resp. 2.0.0.10 (GS308EP/EPP), the uC on these switches - like any earlier Plus Switch (newly designated with a Web UI - listened to IPv4 connections requests (ping, Web UI, ...) on any channel, on any port, on any VLAN - as long as the request came to the IP address configured -and- over an [U]ntagged connection, no matter on the switch VLAN configuration.
The users of GS108EP/EPP - using the identical firmware image like the GS308EPP - are likely experiencing the same with the update to 2.0.0.11 ...
The Management VLAN can be configured in the switch Advanced 802.1Q VLAN settings. What impact this enhancement has to the GS108EP/EPP and GS308EP/EPP models in the other modes (like No VLAN, Basic Port Based VLAN, Advanced Port Based VLAN, or Basic 802.1Q VLAN) has ... I don't know.
I have not checked if the Management VLAN control is available in the other modes. On the bigger models built on Managed Cores, the Management VLAN control is right on the main page of the Web UI, as there it's globally applicable.
However, during earlier Beta tests, I had complained about the to many confusing modes ... oh well.
Note: I'm not Netgear, just yet another Netgear Community member.
