KLelong
Oct 30, 2022Aspirant
GS308T & VLANS
Hi, I just purchased a GS308T to replace on older switch. I seem unable to successfully configure the VLANs. I want this (works on the old switch) : Port # 1 2 3 4 5 6 7 8 VLAN 1...
- Oct 30, 2022
Never mind. I got a recommendation after posting my problem. There is the function of PVID explained so I did understand.
Every untagged port should belong to the same PVID as the VLAN it should belong to.
KLelong
