kmman
Aug 06, 2021Aspirant
GS316EP List of connected MAC addresses?
Hello. GS316EP can support up to 4K mac addresses as per factory specs. Any idea on how to list that MAC address table? Need to find Mac addresses connected to the switchports but cant seem ...
kmman
schumaku thanks for the answer.
That is sad to hear.
At the same price you can get S3260-16T4FP that supports 4 SFP ports, CLI, SSH and access to similar internal switch functions without an issue.
If only I knew that before ordering.
schumaku
Aug 06, 2021Guru - Experienced User
Not really, at least not what I see here in Swizerland - the small formfactor and fanless GS316EP is less than 200 CHF, the other brand Smart Managed Pro type switch with a fan (and PoE+ capabilities and a slightly higher power budget plus SNMP) is at least 50% more expensive (> 300 CHF here). Two very different products.
Netgear does also offer Smart Managed Pro type switches of course, for example an 24 port PoE+ GS324TP is still 20% below the other vendor price (~260 CHF here).
