fmac77's avatar
fmac77
Follower
Jul 04, 2025
GS316EP POE is dead
Hello everyone, I got a GS316EP switch with PoE, everything worked fine with 3 APs WAX610 but now there is no PoE anymore.
GS316EP is on the newest firmware, I resetted it etc.
APs are working fine if they are powered externally but not with PoE.
I also ordered a PoE Tester and there is also no power over the cable.
I also tested directly at the switch.
PoE Settings for the port are standard:
IEEE902
802.3at
30 W
But the status (same for every port) shows deactivated, 0 V, 0 mA, Status: No Errors, 0 W but Temp 275 C°.
Can someone help me out?
1 Reply
  • Hello, I have the same problem! Also downgrading to two earlier versions and reset did not help…
    is the function now bricked?
ProSupport for Business
