TCTC's avatar
TCTC
GS324T - Seems that 10/100 devices will not connect properly
Hello,
I just purchased a used GS324T switch.  I have Port 1 plugged in to a Nighthawk wireless router.  The wireless router is connected to a cable modem.  All wireless clients on the Nighthawk work.  All 10/100 and Gig devices plugged directly in to the Nighthawk work.
None of the 10/100 connections plugged in to the GS324T appear to work.  Those ports who have 10/100 devices connected blink orange, but those devices are unable to connect to anything.  These 10/100 connections aren't very intelligent (Chamberlain MyQ, Samsung TV, Roku 3), so troubleshooting is limited.  When I plug these connections directly in to the Nighthawk, they work properly.
I connected a laptop with a 1gig network ethernet card in to one of the network jacks that a Roku 3 was plugged in to (wireless was disabled on the laptop).  The laptop connected to the ethernet network just fine and was able to reach the internet.
I am currently running firmware 1.0.0.27.  There was a second image with the 1.0.0.16 firmware on it.  I activated and booted to it and got the same results.
  • TCTC
    Welcome to the community! :)
    Activate again the latest firmware v1.0.0.27 on the GS324T then perform a factory reset.  Check if the same problem occurs.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    TCTC
    DaneA
    • TCTC's avatar
      TCTC
      Thanks DaneA, that did the trick.  I must have goobered something up when I was doing the initial config (I had previously done a factory reset last week).
ProSupport for Business
