AlanKilgore
May 03, 2022Aspirant
GS724T no browser access even after factory reset
I am not able to access several GS724T1 switches using a browser or the NETGEAR Switch Discovery Tool 1.2.103 The switches still work but I have not been able to gain access even after holding th...
- May 05, 2022
Hi AlanKilgore,
For GS724Tv1, please use the Smartwizard Discovery Utility 2.5.5 to discover the switch and check the User Manual on how to use the utility. https://www.netgear.com/support/product/GS724Tv1.aspx#docs
User Manual: https://www.downloads.netgear.com/files/FSxxxT_GSxxxT_smartswitch_UserManual.pdf
Mary
DaneA
May 04, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Since you have already factory reset the GS724Tv1 switch, its IP address will be back to its default which 192.168.0.239. Connect a PC directly to any port of the GS724Tv1, assign a static IP address such as 192.168.0.210. Open command prompt on the PC then check if you are able to get replies when you ping the default IP address of the switch.
If you are able to get replies when you ping the default IP address of the GS724Tv1 switch, open a browser such as IE7 or IE9 (Internet Explorer 7 or 9) then try to access its web-GUI. Be reminded that the GS724Tv1 is an old model of switch and it is already EoL (End of Life) years ago that is why an old browser is recommended to be used.
DaneA
NETGEAR Community Team
AlanKilgore
May 05, 2022Aspirant
Thankyou for your response.
After the factory reset I already tried connecting to the default IP using proper range computer IP and mask.
Neither GS724Tv1 switch responds to pings but both still work as unmanaged switches. If it won't respond to pings I am thinking that there is no hope for for any web browser to access its webserver. Or, is there an internal hardware jumper that I can try for a lower-level factory reset?
I have a GS724Tv3 that continues to work in all respects.. When I tried to order another v3 or v4 last January, they were unavailable for many months, like many such IT products at that time. So, I bought a competing product to meet immediate needs. But I would like to restore these GS724Tv1 models if I can. Is there any hope for them to be anything more than a non-managed switch at this point?
- Nodism1125May 05, 2022NETGEAR Expert
Hi AlanKilgore,
Mary- AlanKilgoreMay 05, 2022Aspirant
Thanks, Mary. That was the solution that I needed. The discovery tool that I had previously tried would find our v3 switch but did not work for the v1 switches. The discovery tool you referred me to completely resolved our problem.
