Cristinasust
Jan 22, 2018Tutor
GS724T unable to read the MAC address using SNMP
I connect a device with a MAC on port 1 of the switch. Normally I used a MIB library called BRIDGE-MIB that if I put the OID to find the port followed by the MAC I am looking for, in decimal, the swi...
- Jan 31, 2018
Finally I solved with the following OID:
1.3.6.1.2.1.17.7.1.2.2.1.2.1.0.64.157.62.182.191
where 0.64.157.62.182.191 is the MAC address of my device.
Thanks for your help.
DaneA
Jan 23, 2018NETGEAR Employee Retired
Hi Cristinasust,
Welcome to the community! :)
What is the exact model of the GS724T switch you have? Also, what is the current firmware version of it?
If ever you have the GS724Tv4 switch, it latest firmware version is v6.3.1.19 that can be downloaded here and its corresponding MIB v6.3.1.19 can be downloaded here.
Also, you may want to try using the NMS300 which is a network management software by NETGEAR to isolate the problem. You can download its latest version 1.6.0.3 here and its documentation here.
DaneA
NETGEAR Community Team
Cristinasust
Jan 23, 2018Tutor
Dear DaneA,
Yes, I have this version and this firmware. I have also the MIB libraries, but I don't know wich one to use if i want to read the MAC address.
Is it necessary the software that you mentioned?
Thank you,
Cristina
