Cristinasust
Jan 22, 2018Tutor
GS724T unable to read the MAC address using SNMP
I connect a device with a MAC on port 1 of the switch. Normally I used a MIB library called BRIDGE-MIB that if I put the OID to find the port followed by the MAC I am looking for, in decimal, the swi...
- Jan 31, 2018
Finally I solved with the following OID:
1.3.6.1.2.1.17.7.1.2.2.1.2.1.0.64.157.62.182.191
where 0.64.157.62.182.191 is the MAC address of my device.
Thanks for your help.
DaneA
Jan 23, 2018NETGEAR Employee Retired
Hi Cristinasust,
Welcome to the community! :)
What is the exact model of the GS724T switch you have? Also, what is the current firmware version of it?
If ever you have the GS724Tv4 switch, it latest firmware version is v6.3.1.19 that can be downloaded here and its corresponding MIB v6.3.1.19 can be downloaded here.
Also, you may want to try using the NMS300 which is a network management software by NETGEAR to isolate the problem. You can download its latest version 1.6.0.3 here and its documentation here.
DaneA
NETGEAR Community Team
DaneA
Thanks for the feedback. To isolate the problem, kindly try using the NMS300 and check if you can accomplish your goal.
DaneA
- CristinasustJan 31, 2018Tutor
- DaneAFeb 01, 2018NETGEAR Employee Retired
Thanks for the update. I'm glad to know that the problem got resolved. :)
Since your concern is now resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
