richai's avatar
richai
GS724T v?
I have a customer with 4 gs724t smart switches.  They recently had a audit (they are afinancial institution), and the audit recommended they thurn off telnet.  On the v4 of this switch the GUI interf...
  • DanielZhang's avatar
    DanielZhang
    May 20, 2018
    Hi Richai,
    Thanks for your confirmation.
    Please upgrade to 6.3.1.19 if switches are GS724Tv4.
    The new firmware enhanced the feature just you want(Remote Diagnostics)
    Please reference following guide to upgrade:
    How to upgrade GS724Tv4 to 6.3.1.19.
    May the solution help you.:smileyhappy:
ProSupport for Business
