richai
May 17, 2018Aspirant
GS724T v?
I have a customer with 4 gs724t smart switches. They recently had a audit (they are afinancial institution), and the audit recommended they thurn off telnet. On the v4 of this switch the GUI interf...
- May 20, 2018
Hi Richai,
Thanks for your confirmation.
Please upgrade to 6.3.1.19 if switches are GS724Tv4.
The new firmware enhanced the feature just you want(Remote Diagnostics)
Please reference following guide to upgrade:
How to upgrade GS724Tv4 to 6.3.1.19.
May the solution help you.:smileyhappy:
richai
May 18, 2018Aspirant
I am not sure how to reply to the response to my question but, the switches are V4 and are out of date on the firmware. Is updating the firmware the same as other hardware, download on PC and push to switch, ot is there a special way to do it? Thanks for your quick response on the initial question.
- DanielZhangMay 20, 2018NETGEAR Expert
Hi Richai,
- richaiMay 25, 2018AspirantThe fimware update solved the problem. Thank you.
