richai
May 17, 2018Aspirant
GS724T v?
I have a customer with 4 gs724t smart switches. They recently had a audit (they are afinancial institution), and the audit recommended they thurn off telnet. On the v4 of this switch the GUI interf...
- May 20, 2018
Hi Richai,
Thanks for your confirmation.
Please upgrade to 6.3.1.19 if switches are GS724Tv4.
The new firmware enhanced the feature just you want(Remote Diagnostics)
Please reference following guide to upgrade:
How to upgrade GS724Tv4 to 6.3.1.19.
May the solution help you.:smileyhappy:
santoshs
Aug 02, 2024Aspirant
I have Netgear XS712T and it does not have remote diagnostic option to disable.
I want to disable Telnet on this Switch due as it shows port 60000/Telnet open.
I am using 6.1.0.33 Firmware
Is there any other way to disable the Remote Diagnostic/Telnet
