richai
May 17, 2018Aspirant
GS724T v?
I have a customer with 4 gs724t smart switches. They recently had a audit (they are afinancial institution), and the audit recommended they thurn off telnet. On the v4 of this switch the GUI interf...
- May 20, 2018
Hi Richai,
Thanks for your confirmation.
Please upgrade to 6.3.1.19 if switches are GS724Tv4.
The new firmware enhanced the feature just you want(Remote Diagnostics)
Please reference following guide to upgrade:
How to upgrade GS724Tv4 to 6.3.1.19.
May the solution help you.:smileyhappy:
RennaD
Aug 06, 2024NETGEAR Moderator
Hi santoshs,
Welcome to the NETGEAR Community! 🙂
Since there is no Remote Diagnostics in GUI this means what you have is XS712Tv1. To disable Telnet access you can instead run the command below to set the number of Telnet connections to "0" users:
(XS712T) >enable
(XS712T) #telnetcon maxsessions 0
RennaD
NETGEAR Team
santoshs
Aug 06, 2024Aspirant
Hi Reena,
There is no console port on XS712T.
How to access console on XS712T?
Thanks for your help
- RennaDAug 07, 2024NETGEAR Moderator
Hi santoshs,
You may connect to one of the ethernet ports. Then using terminal emulator open a Telnet session to the switch IP address using port 60000.
RennaD
NETGEAR Team- santoshsAug 12, 2024Aspirant
Hi Reena
THanks for your help..
If I disable the telnet port from the terminal, is it possible to enable it back again and how?
as I do not see any option for telnet in GUI.
- RennaDAug 13, 2024NETGEAR Moderator
Hello santoshs,
Once change has been made, a factory reset has to be performed to be able to connect to the switch via Telnet again. As this will delete all configuration, I suggest to save the config file first before making any changes. This way you would be able load the config file (with Telnet enabled) in case you need to re-enable Telnet access.
Have a lovely day,
RennaD
Netgear Team
